Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Conversions
 Converting Magnum .90 glow to gas ignition >
Old 07-05-2007 | 01:28 PM
Default Converting Magnum .90 glow to gas ignition
Hello all,
I have Magnum 91 glow engine and I want to convert it to Gas ignition. Can someone help me as what I need to do or any place that will sell the conversion kit?
Borna
Old 07-05-2007 | 01:50 PM
av8tor1977's Avatar
Default RE: Converting Magnum .90 glow to gas ignition
You can get the ignition and accessories at www.ch-ignitions.com.
However, you will still have to run a high (18%?) percentage of oil unless you can find a way to convert the rod bushing to a roller bearing, and either harden or replace the crank pin.
AV8TOR
