Favorite Engine for Conversion
Old 07-28-2007 | 10:35 AM
Default Favorite Engine for Conversion
If you had your choice of engine brand and size from a weed eater or leaf blower what would you choose?
This will help me decide what I should get to convert. Also, if the carb needs to be replaced please let me know.
Old 07-28-2007 | 10:42 AM
av8tor1977's Avatar
Default RE: Favorite Engine for Conversion
First choice Echo, second Homelite. Most all weed whacker engines respond well to a larger carburetor.
AV8TOR
Old 07-28-2007 | 04:32 PM
Ralphbf's Avatar
My Feedback: (27)
Echo 23.6cc. The older model are the best.
I want to build a 25cc Echo with a 23.6 cylinder.
Old 07-28-2007 | 05:54 PM
shaunmichaeljohnson's Avatar
first echo and then "talon" (cheap trimmer but plenty of power and full shaft) adn then after thoes 2 a homelite.
shaun
Old 08-02-2007 | 05:05 AM
OK then, Echo it is. Would you recommend a change in carb? what model number?
