Pics for Homie engine mounting.
Old 02-19-2008 | 12:00 AM
KI8FR's Avatar
Default Pics for Homie engine mounting.
Can some of you put up some pics on how you all mount you homie 25cc
I need 6 ½ “ from the prop to the firewall. So that will be 1 to 1 ½” of stand offs that I will have to put behind the engine. I not to king on the idea of ordaining stand offs so I will have to make them. So right now I am looking for some good ideas if you will send them my way.
Paul
Old 02-19-2008 | 12:29 AM
My Feedback: (13)
Default RE: Pics for Homie engine mounting.
on my latest engine, I made some standoff's on my lathe, drilled out 3/4 of the length to just above the size of 10-24 allthread, then tapped the end that wasn't drilled too big, replaced 4 of the case bolts with the allthread, installed the spacers with the threaded portion furthest from the engine and tightened, I left enough of the allthread sticking out the back to go through the firewall and used nyloc nuts and fender washers on the other side of the firewall.
this method works well, although I haven't technically ran an engine with it, it's plenty strong, and allows for the least amount of bending in the weak allthread so it should actually hold up...
although this isn't a homelite obviously, it should show what I was trying to explain
ID:	882869   Click image for larger version
Old 02-19-2008 | 01:00 AM
KI8FR's Avatar
ORIGINAL: rangerfredbob
What to you meen by nyloc nuts? Is that the same as lock nuts? If not were did you get them and why did you uses them?
I know what you are taking about with the stand off. but I do not have a lathe. YET lol
I will get one. Just do not know when yet.
You did a nice job on the ones in the pics.
Thanks Paul
Old 02-19-2008 | 01:27 AM
My Feedback: (13)
yeah, usually the same thing, it's just the nuts with the little nylon insert
I'd have to check my material, but I could possibly make you up a set including the allthread, I have a homelite to use for mochup...
Old 02-19-2008 | 02:17 AM
KI8FR's Avatar
Pm me on how much you need to do it and I will see how long I have to have them.
thanks
Paul
