Stiks for conversions?
Old 04-29-2003 | 11:55 AM
Default Stiks for conversions?
Planning my first gas conversion project. Looking in the 31cc vicinity. I want something quick to build (ARF) under $200, basic acrobatics. Stik planes are probably the ticket here. How about a GP BigStik 60? Other contenders for the throne? A search reveals limited results for stiks. Thanks.
Old 04-29-2003 | 02:20 PM
Default UltraStick 1.20
Best ARF combo I've see so far is the H9 UltraStick.
Here's a thread with converted Ryobi...looks sharp...
One of the secrets is to look at the WING AREA...
GO for about 1200 square inches if you can...
With the Ryobi 31cc conversion, I would bring the nose back about 1-2 inches though...easy modification. And put the elevator and rudder servo in the tail.
http://www.jagengines.com/Ultra31.htm
http://www.modelairplanenews.com/reviews/ultra.asp
A good thread here on one...
http://www.rcuniverse.com/showthread...01&forumid=257
Good luck!
CrazyHerbb
Old 04-29-2003 | 08:28 PM
ANeat's Avatar
My Feedback: (15)
I would like to find a good airframe similar to a "stick" style plane for the Poulan 46. Something like a Modeltech Magic or similar layout ; just BIGGER. I would even scratch build something if a good design is out there.
Did they stop making the 120 Ultra Stick??
Adam
Old 04-29-2003 | 09:01 PM
I'm just about to finish up a UltraStick with a G38 with CH Ignition
Three servos in the tail and four in the wing plus throttle...
Wires are going everywhere...
Can't wate....
Old 04-29-2003 | 11:42 PM
I'm flying a Hangar 9 Ultra Stik on a homey 25cc and about to HOP-It-Up to a Homey 33cc.
For lots of articles and links to conversions try
http://webpages.charter.net/rsengineconversions/
You just can't beat the designs and engineering involved there.
flyguy2002
Old 04-30-2003 | 12:15 PM
mstroh3961's Avatar
Default plane
Hi you don't mind scratch building, you might look at the Ryans Rebel in the November RCM mag. engine choice is ryobi 33cc, g38, or reinforcing the fire wall if you go bigger, according to the designer. He posts on this forum as RYAN'S REBEL.
Mark
Old 04-30-2003 | 01:42 PM
tkg
Default Stiks
There is a kit called a Road Runner thats about the best for these engines. It was designed to fly with a 120 4c and up.
I seen about 6 with various weedies in them.
Check in NIB Kits, or just use search for some pictures. Call 307 856 4630 for $$ and info
Old 04-30-2003 | 04:32 PM
Default Gas Stick
Does anyone have any experience with the Big Stick from Bridi?
http://www.bridiradiocontrol.com/acb..._ID=30&CATID=5
Old 04-30-2003 | 06:54 PM
Look at the Big Bee from Bridi...(Not to get off the thread..)
Flies like a big Cub...
Old 04-30-2003 | 10:48 PM
rsrogers's Avatar
My Feedback: (10)
Theres a member of our club who has the Big Bee. He is using a 33cc converted Homelite from RS Engines and for a 100" plane it flies great!!
Keep'm Off The Ground!!
Steve
Old 04-30-2003 | 11:42 PM
Panzlflyer's Avatar
My Feedback: (15)
The Ryans rebel is an easily built plane for minimul cost.
Old 05-01-2003 | 01:00 AM
If you would like some thing ultra inexpensive and a little unusual maybe a giant SPAD would work. Without the radio a couple nights and about 20.00 worth of mat. and you have a giant trainer. Pics in my gallery. Steve
Old 05-01-2003 | 02:46 AM
Default Giant Spad Stick
Nice JOB!!
Got any dimensions on that SPAD?
Span, Chord, Horz Stab Span...fuse length...ect...
I've been thinking about doing just that...only copying a 1.20 UltraStick...
I've done a even simpler design for the beam-style motors like Homelite 33/45 and Poulan chainsaw engines... ALSO in my gallery. Using 6 ft pine/poplar furring strips 3/4 x 1 1/2.
Using one for spar and two for a "rail-type" fuse... 60 inches long, 72 inch span...
This isn't the giant cub SPAD that I saw video of torqe rolling is it?? Totally trippy...I'll post a link here if ya'll want to see it...
CrazyHerb
Old 05-01-2003 | 10:50 AM
Very good ideas. I've searched for an Ultra 120, none to be found.
I am currently flying 4 SPADS of various designs. I've pondered a 31cc Spad design, but was concerned about weight. Only a couple successful gas models on various Spad websites. A gas DPS type would be interesting. The Spad concept and gas conversions seem to be a good match.
Can't seem to find the Big Bee...will search more. The Big Stik looks like a possibility.
To conversion vets...it seems there are a variety opinions of ways to go (cc size wise)...does it make sense to start at least at 31cc with the type of planes we are discussing?
Old 05-01-2003 | 01:35 PM
Try this
Can't beat the price for the kit...
He may have a kit left and may not..
Old 05-01-2003 | 03:50 PM
I bought a Big Bee here:
http://www.sheldonshobbies.com/listing/hotdealair.html
Good or bad, I also bought a Macs tuned pipe here as well. (MAC1196)
http://www.btown.com/sheldons/listing/mac.html
I need to either make a header or suck it up and buy one direct from Macs (expensive).
I've raised and enlarged the exhaust ports on the Ryobi and installed a new ring. The compression is definately better than the stock one. I need to pick up a tach. The engine does seem to run stronger (screwed into a fencepost) but don't have any numbers to prove it. I'll need the tach to try out the pipe.
I get a big grin every time I fire up that motor!
Mark Napier
Old 05-01-2003 | 09:03 PM
Whooooooo, Bridi isn't showing the Big Bee....must be out...
Have you really got a Ryobi 31 on this..(Gotta ask)
Had to put a G62 on mine.......GRINNNNNNN!!!!!
Won't land on a paved runway....but goes straight up....
Would be about right for a Poulin 46...
Old 05-01-2003 | 09:22 PM
Default Let's snap back...
Back to original post...
Still points to the UltraStick...anyone got any other $200 or less arfs that the Ryobi 31cc will fly (decently)????
CrazyHerb
Old 05-01-2003 | 09:34 PM
Sorry to get of the thread..should have sent a PM...
This is my first ARF with the Ultra Stick....and probably my last ARF...
By the time I get this one tricked out, I really could have built and covered two...
Old 05-01-2003 | 09:40 PM
Default No Prob...
No Prob on my part Big Bird...I enjoy the off-topic posts just as much....this place is such a wealth of knowledge...
Its just a bummer with the "tone" gets negative...I ignore those threads.
Take the moral high ground....in any situation...
I've been tossing this SPAD UltraStick idea around for a couple days.....sounds very feasible ...at ARF assembly time and durable to say the least....shouldn't be more than 50 bux of materials for an entire airframe.....
High Flights!!
CrazyHerb
Old 05-01-2003 | 09:45 PM
ANeat's Avatar
My Feedback: (15)
Does anyone still sell the Ultra Stick??
Herb; How about a 70" or so QHOR!!!
Adam
Old 05-01-2003 | 10:19 PM
Some UltraSpad design possibilities...?? I'll start the discussion
Wing...2 mm, 80" span, symmetrical airfoil around a 1.5" spar...cord width?...dihedral?
Fuse...coro with formers...length?
Tail feathers....size?
31 CC engine
Old 05-01-2003 | 10:20 PM
maybe we should move to Spad section?
Old 05-01-2003 | 10:43 PM
No biggie....
Old 05-02-2003 | 12:02 AM
Thanks for the positive coments CrazyHerb. 96"ws 18"cd 14lb I just incresed the tail size b/c it took a lot of travil to make it respond right. Steve
