Need info on this engine
Old 04-05-2008 | 11:53 AM
Antique's Avatar
Default Need info on this engine
Need some information about a Shinidawa a friend of mine has. The only markings on it is 1R20 No pictures, anybody have any ideas ? Displacement ? Anybody done one of these ?
Old 04-05-2008 | 09:51 PM
buck1856's Avatar
My Feedback: (49)
Default RE: Need info on this engine
I had one once,about 21-22cc.Light,2 rings,basiclly a copy of the echo.The only thing i didnt like was the flywheel was turned backwards so the fins where facing the block and the space that the hub would screw onto was only about 3/8ths to 1/2 inch around.[if i remember right].I didnt have a milling machine or even a drill press so i couldnt shave the lip out of the flywheel.I didnt have a lathe yet and was just starting into conversions so i sold it to a guy in CA.I think it would be dead on in comparison to an echo.Maybe a little lighter.
Old 04-06-2008 | 12:24 AM
Antique's Avatar
Thanks Buck ,,,,,,,,,,,,,,
Old 04-11-2008 | 10:56 PM
buck1856's Avatar
My Feedback: (49)
I have 3 or 4 shindaiwas coming to me around the 14th.Ill check what the numbers are on them.And check weight.
