Can your run a glow 4 stroke on gas???
RE: Can your run a glow 4 stroke on gas???
ORIGINAL: icando3d2
Anyone tried to run a glow fourstroke on gasoline?
gas fuel with glo plug no ignition
http://www.rcuniverse.com/forum/m_12...tm.htm#1267448
Good luck,
Dave Olson
Using ignition....
http://www.rcuniverse.com/forum/m_7282593/tm.htm
My Feedback: (15)
VA
Ok guys thanks for the input. I have decided to convert my glows to gas after reading the good responses on the posts. So today i ordered my spark plug from ngk "i work at Advance Auto parts" so that part was the easy part now if we only sold ignitions lol can i get some input on which box is economical and reliable. as soon as i get parts in i will post pics readings and so forth if you guys are interested, I know im excited.
My Feedback: (15)
VA
hey guys for a saito 100 or os fs 120 do i need to do any busing to bearing swaps if not what mix do i use i dont want to burn it up because of not asking.
thanks
chris
thanks
chris
If you do not make any modifications, run the engine on the specified oil percentage as with traditional glow plug, but make sure to use a bit of castor, since the fuel to air mix is different.
