Gas/Glow
I have never converted a 4 stroke glow to gas/glow, but I did converted my Magnum 180 to gas glow, just make sure you use between 6-10 % oil content, what I did was to take the 20/20 glow fuel and used 1 part glow fuel with 2 parts 91 octane gasoline, this should give you about 6.66% oil content 6.66% nitro,20% methanol and 66.66% gasoline, you may add some extra oil if you wish if you want to bring it up to 10% oil, let us know how it works with the 4 stroke.
Aero Nut.
Aero Nut.
With a 4 stroke engine...oil will collect in the crankcase. This is a good thing that may allow you to use less oil in the fuel. You will have to expeiment to find out. Best Regards capt,n
JUst engines in the UK now has a CDI ignition system looks quite good and appears to be about $80 after the dollar/GBP exchange it is shown running asp 80 4 STK THE 1/4-32 SPARK PLUG about an other $8 they are running 15/1 GAS OIL AT THIS POINT and claim twice the run times as glow fuel per tank martin
Have delt with them for years for my glow and diesel engines outstanding service
THe ASP and magnum and SC 4 strks are all the same just different name tags
