Which Homelites do I have ?
I have 2 Homelite engines I am in the process of converting. I thought they were both 30cc, but I am seeing some diferences. One engine has a single ring piston with the little exhaust port on the cylinder. The other engine has a slightly bigger diameter piston, no exhaust port and is double ringed. Other than those differences they appear to be identical. Any ideas ?
The smaller of the 2 has been run with a scratch built muffler and is turning an 18x6 prop at 7400, the other one has not yet been run.
Thanks in advance
Scott
Thanks in advance
Scott
Sounds like one may be a "new and improved" version of the other.
