Yard Man Motor
Hey Guy's what engine is this on the Yard Man ,Model YM-400 ?
It is a 31cc Engine that Wallie World has ,for $79.86.
It looks like a Ryobi. Don't know for sure.
Need Imput
Need Imput
TN
If it's a rear carb and rear exhaust, it's a Ryobi. I'm seeing some now with an integrally-cast fan housing backplate vs. the traditional bolt-on fan case that Ryobi's originally had. Does yours bolt on???
Hey Volture~~~ Looks like to me it is a bolt on, from what I can see, may be for the clutch :stupid: ?
There are 4 screw points on it , just like a backing plate, on a Homie.
That sounds Good then, for $79.00, you can have a new Ryobi 31cc engine, if it will work.
And yes it is a rear exhaust , and rear carb.
Thanks for the help, Big V
CO
Hi I just bought that same one! It look just like the on on my ryans reble! exept it's a twin ring! Im thinking about swaping the two after its broken in on the trimmer!
I got the floor model 10% off!
Regards
Mark
Regards
Mark
