Rainy day Project!
Old 09-08-2008 | 05:11 PM
Default Rainy day Project!
Well I thought I would make a exhaust system for my gas engine. I made a little adapter (between .750 dia pipe and bottle) on the Lathe to keep pipe in alightment before its welded. So far so good. Capt,n
Old 09-08-2008 | 05:41 PM
Default RE: Rainy day Project!
Have the same setup on a large glow motor well worth the looks from the boys at the feild if for no other reason !!!
Old 09-08-2008 | 07:05 PM
What engine do you have the exhaust on? Lower power or higher than stock. Tell us the good and the bad....please. Thanks Capt,n[:-]
Old 09-08-2008 | 07:38 PM
i see 4 cast connecting rods ready for machining.
just what ARE you making
Old 09-08-2008 | 07:42 PM
My Feedback: (13)
those are for his Holt 4 cylinder you can see in the background...
Old 09-08-2008 | 10:30 PM
ORIGINAL: flyguyeddy
REPLY: I am working on (sometimes) a model Holt Catapillar engine. Those rods have quite a lot of work already. You shoud have seen the rough castings! Capt,n
Old 09-09-2008 | 11:41 AM
I have my set up on an older 1.20 webra with my cheap tach I seem to gain about 800 rpm on the top end. and It helped me get the cg back a bit. but like I set the best part is the comments at the feild
Old 09-09-2008 | 09:58 PM
Well a 800 RPM gain is good... I would say! My Friend has a 1.20 Webra, called a Bully. It has twin Glow plugs. He has 2 or 3 Webra 1.2 engines. I put a Frank Bowman piston ring in it and what a difference that made. The compression is way better than his other Webras! It will flip start now...it has very good compression with that ring. Best Regards Capt,n
