Marine engine to Air
Old 10-19-2008 | 06:58 PM
Tidnab's Avatar
My Feedback: (51)
Default Marine engine to Air
I have a Zenoah 260 PUM marine engine I was thinking of converting to an airplane engine.I've found the crankcase,crank,piston are the same as the G26 air.I 'd have to get a cylinder,prop hub and take off the recoil starter.I can use the leftover parts to build a better modded Zen 260 marine engine later on ,as I already have a crankcase and piston set and will have the jug and recoil off this engine.Figured it would be cheaper than buying a new G26 air.Has anyone done this conversion on a marine to airplane engine?
Old 10-20-2008 | 10:33 AM
Default RE: Marine engine to Air
Ralph at rcignition.com can tell you what you want to know. Call later in day...he likves out west... a few hours later than PA. http://www.rcignitions.com/forum/ That link may help. He is a great Guy to talk to about engines. Capt,n
Old 10-20-2008 | 04:54 PM
av8tor1977's Avatar
He lives in Williams, Arizona. Two hours earlier than Eastern Time.
AV8TOR
Old 10-20-2008 | 07:19 PM
ORIGINAL: av8tor1977
AV8TOR
What ever...but you want to call him later from PA or you will be calling him to eary in the AM. He may be sleeping yet. With daylite savings time...too early for sure!!!!! Capt,n
