Spring tension on throttle
Old 10-31-2008 | 09:08 AM
Default Spring tension on throttle
I have a 34cc Briggs & Stratton Fource 4 cylcle motor converted for aircraft. I made a spacer for the carb and cut the spring tension back on the throttle. It will run at idle or with the choke almost closed. I thought it may be sucking air. Checked the gaskets and they are not leaking. I think when I trimmed the spring for less tension that without the tension it leaks in air around the barrel. Any thoughts on changing the carb or fixing this problem.
I don't want that spring tension on the servo all the time so would like to find a more RC friendly carb with less tension and easy movement.
Eric
Old 10-31-2008 | 09:50 AM
av8tor1977's Avatar
Default RE: Spring tension on throttle
It may not have a leak, it may just be too lean. When you run a more open exhaust and without an air cleaner, that leans out the carburetion, which is too lean to begin with anyway. You need another, adjustable carb.
AV8TOR
Old 10-31-2008 | 10:18 AM
That makes sense. It has a WYL-451 carb. 9.0 venturi, 12.0 choke bore, 9.0 throttle bore. 31mm on centerbolt pattern.
Any suggestions for a replacement?
Old 10-31-2008 | 07:37 PM
The Raven's Avatar
ORIGINAL: the mother of invention
Eric
I have yet to convert my engine but I intend to try a different carb. While the one provided will get you to around 5500rpm (tested on a friends 'stock' conversion) I think some more rpm is required and probably more tunability. My intention is to try a Walbro taken off a Ryobi 31cc (I have several from conversions), if that carb can flow enough for a 31cc 2 stroke at 7000rpm it should flow plenty for a 34cc 4stroke at approx 6000-6500rpm. The nice thing with the Ryobi Walbros (at least the ones I have) is they have both a high and low needle and are not compromised by being an EPA model.
Old 11-08-2008 | 02:11 PM
jtisch's Avatar
You can also drill out the main jet on the WYL, I did that on my 40cc Briggs.
J
Old 11-10-2008 | 03:37 AM
In my converted GX35 I installed WYK-194 sold at www.davesmotors.com
2 needle carburator, diameter 10.5mm.
Works very well, maybe it also fits to B&S engine
Regards
Thomas
Old 11-10-2008 | 10:11 AM
Is this the page http://www.davesmotors.com/s.nl/c.88...egory.27872/.f Capt,n
Old 11-11-2008 | 02:11 AM
Yes, it is, if you scroll down you find the carb in the middle.
It is the same design as the original from Honda, but full adjustable, no main jet but H-needle
Regards
Thomas
