ECHO 21cc -FPE 1.3 clone -operating specs
OK I finished breaking in my echo 21cc-here are specs:
echo 21cc srm2100 short block -new
crrc pro 26i replacement cdi ignition-auto advance
crrc pro 26i hall sensor
crrc pro 45 prop hub
custom made adapter for prop hub
stock muffler opened up slightly from exhaust port side and cut open a little on outlet side
stock carb isolator machined down and pulse port channel machined for carb mount copy of fpe1.3
walbro WA 163 carb-9.5mm venturi
running on zenoah 2 stroke oil at 50:1 ratio 93 octaine gas (31 degrees on timing)
Total flying weight less ignition battery includes -eng-ign-muffler-carb-prop-hub = 45 oz
APC 16 x 4W prop best RPM 8300........
I'm a happy camper!!!
or should I not be??
Stock fpe specs are around 43oz and an APC 16 x 8 @ 7450 rpm
I'm a happy camper!!!or should I not be??
With that APC 16x4 prop seems like doing nothing at all to the engine would turn just as good RPM. I am not sure though. Put the APC 16x8 prop and watch the RPM drop. Maybe more break-in is needed. Capt,n
ORIGINAL: IDM
Hi Mark
Glad to hear your happy, did the carb isolator and other parts work ok.
Ivy McNeil
Hi Mark
Ivy McNeil
I know but i figured the fpe with 16 x 8 prop has around 10 - 10.5 lbs thrust and well............I over do stuff, anyways it has a wing of 810 sq in flying wight of around 7 lbs with the .60- .90 engine.
