Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Conversions
OS Max 91 Four Stroke - Torque vs. HP (and killing the engine!) >
Old 06-02-2003 | 08:18 PM
Default OS Max 91 Four Stroke - Torque vs. HP (and killing the engine!)
I am running an OS 91 Surpass on a Hanger 9 P51D using a 15x8 prop. The engine has some serious pull but the engine, on 10% nitro fuel (albiet it is still relatively new) is only giving 7,500 rpm at full throttle.
More power to take off, more power to climb, but with the wooden prop (14x6), I might have had more speed in flight. Not that speed really matters on a scale war bird, but my question is - am I harming the engine? Is 15x8 too large? I like the thrust I get - what should I use for a prop on a 91 Surpass?
Nomi
Old 06-02-2003 | 08:24 PM
C_Watkins's Avatar
My Feedback: (10)
I'd try a 14x8 or a 15x6. I believe the 15x8 is lugging that engine.
(That's more a 120 sized prop than a 91 sized)
The 15x6 will probably give you more thrust, in the first place.
Old 06-02-2003 | 09:38 PM
ptgarcia's Avatar
My Feedback: (36)
I agree with C_Watkins, you're over-propping the engine. I'd use a 14x8 on the P-51.
Old 06-02-2003 | 09:56 PM
C_Watkins's Avatar
My Feedback: (10)
Doh... missed the P-51 part.
You're right, the 14x8 is probably a better match for that airframe.
