Saito 150s
Old 06-10-2003 | 06:20 PM
Wulf's Avatar
Default Saito 150s
I JUST HEARD OF A SAITO 150 DUAL PLUG ENGINE.HOW COME THIS ENGINE HAS DUAL PLUGS ,IS THERE ANY ADVANTAGE TO THIS?DO YOU HAVE TO HEAT BOTH PLUGS WHILE STARTING OR WILL OTHER PLUG LITE FROM COMBUSTION?
RON
Old 06-11-2003 | 10:08 AM
Default Saito 150s
Ron, Saito makes many engines with dual plugs. Why - I don't know for a fact, but suspect it is to help keep the larger displacement engines from losing fire at lower rpms. You only have to heat one of them for starting - combustion will light the other one.
Lynn
Old 06-11-2003 | 10:44 AM
Wulf's Avatar
Default Saito 150s
Thanks ,Lynn,
If it keeps the engine from stopping on landing,it`s a good idea.
Ron
Old 06-11-2003 | 12:54 PM
Default Saito 150s
The Saito 150 will idle all day long with just one plug...It was the best running, smoothest , four stroke I've ever had...
