Ryobi 31 CC
My Feedback: (38)
GA
Anyone know or offer an intake manifold to move the carb on a Ryobi 31 cc from the rear of the engine to the side of the engine lik a Zenoah?
Moderator Corrected Title Spelling
I have thought. about trying to do this also. I havent seen anything like one on the market anywhere. I dont see why one cant make a manifold to screw on to the exsiting manifold that would put the carb where you want it. I kind of like the carb in the back as it makes the whole unit more compact but it sure is a pain to work on. the stock carb location really makes it tough to get the throttle arm to work right.
Maybe you could build a extension of the throttle shaft that has the linkage end out where it would hook up easy. Just a Idea. The Ryobi I am working on has a aluminum plate and I will use standoffs for clearance. Best Regards...Capt,n
