electric leaf blower conversion
RE: electric leaf blower conversion
That would be a darned long extension lead and it might cause some interference with the flight control surfaces if you did to many rolls in the same direction
MI
Just build a bigger plane to carry the weight then add more lipos for more power then build a bigger plane to carry the added lipos then you need more plane to carry the added lipos then more lipos to fly the plane[sm=48_48.gif] Oh where will it all end???????
[>:] But i would work.... would'nt it??????
TX
ORIGINAL: waterloged
I dont think the flying lawn mower was an actuall converted lawnmower. it was an airplane made to look like a lawnmower but i really got to belive that you already knew that. problem with a leafblower would be that it just would not produce enough thrust compared to its weight and also the power problem.
