echo 16cc carb?
Old 06-04-2009 | 09:32 AM
Default echo 16cc carb?
what would u guys suggest i use for an echo gt1000 engine for a replacement carb? this thing has a TINY carb inlet. im thinking that an 11.11 would be TOO big, but i dont know if there is a middle ground, like a 9mm or something. i couldnt tell you what it currently has.
this engine is going to go on a carl goldberg anniversary cub, so worry not about it powering something huge.
Old 06-04-2009 | 01:41 PM
av8tor1977's Avatar
Default RE: echo 16cc carb?
I would say a 9mm carb would work fine.  I think that is what I used on mine years ago.
Good luck,
AV8TOR
Old 06-04-2009 | 01:44 PM
will the gas/glow fuel mix be ok with this engine being as it doesnt have a needle bearing on the piston pin?
anyone know a part number for a 9mm walbro
Old 06-04-2009 | 03:48 PM
av8tor1977's Avatar
I think it will be ok.  The Gas/Glow mix ends up with about 32 to 1 oil ratio, which is probably close to what the engine was run at in its original application.
AV8TOR
Old 06-04-2009 | 07:31 PM
My Feedback: (13)
I was going to use a stock carb off of a homie 25 on mine... should be about the right size, and I have quite a few of them...
Old 06-05-2009 | 06:19 PM
i wish all mine werent zama's.
