Walbro WT-353
Old 08-02-2009 | 10:45 AM
Default Walbro WT-353
Anyone have specs on this? I know it has a primer bulb, choke and two needles, what is the bore 9mm, 10mm ? Where can Ifind this the Walbro site is impossible?
Thanks for any help.
Old 08-02-2009 | 11:22 AM
Default RE: Walbro WT-353
Go to this site, plug in the carb number and it should give you the specs. Good luck.
http://wem.walbro.com/walbro/family.asp
Old 08-02-2009 | 11:31 AM
ORIGINAL: spaceworm
Excellent...Thanks 'Worm...!!
Old 08-04-2009 | 07:02 AM
look inside the inlet side of the carb, there is a number cast into the throat, that is the venturi size in 64ths
Old 08-04-2009 | 09:33 AM
w8ye's Avatar
My Feedback: (16)
The number in the venturi of the carb will be "34" and the venturi size is 13.49 mm
