OS BGX-1 CH conversion questions
Old 04-10-2010 | 06:53 PM
Default OS BGX-1 CH conversion questions
I purchased this engine in the marketplace.appears to be in good shape,has the parts to go back to glow.this has a mechanical advance tied to the carb.The piston skirts is black from either carbon or varnish.I now this is normal for glow what about gas?
I believe the conrod is bushed so what oil and oil mix should be used?
What would be a good starting prop.was thinking of using this in a esm dauntless.
Old 04-10-2010 | 11:42 PM
tkg
Default RE: OS BGX-1 CH conversion questions
4.8V battery for ignition, 12oz of good oil per gallon of gas, 18x10 prop sport flying adjust pitch and dia to suit your flying style.
Old 04-11-2010 | 08:49 AM
thanks,think you mean 18-8 prop.at 12 oz per gallon what ratio is that?and what would be a good oil?there are alot to choose from these days compared to a few years ago.
Old 04-11-2010 | 09:27 AM
With 128 oz/gal wouldn't 12 oz of oil per gallon work out to approximately 10:1 gas to oil?
Old 04-11-2010 | 01:07 PM
tkg
Lets post after coffee, 18x10, 10% oil, Pennzoil. High 7k or low 8k rpm.
Old 04-24-2010 | 12:09 AM
Maximiliano Galvez's Avatar
test It with 10X10 prop
I tests it gas converted I get same rpm with 206-10 with 15% nitro than gas
6700 rpm
Was my firt engine conversion
Now I have finished a new one
This one has no the backplate prezurizatons for pum. Now I modified Walbro. Will take video tomorrow
[link]http://www.amderc.com/osbgxconv.htm[/link]
Max
Old 04-24-2010 | 06:21 AM
10-10 is a 40 size prop why would anyone put it on a 35cc engine
Old 04-24-2010 | 10:35 AM
My Feedback: (13)
I'm thinking that was supposed to be 18-10, 20x6-10 was mentioned lower
Old 04-24-2010 | 09:05 PM
sorry mistake
yes was 20X10
and my best was with 20x6-10
soo sorru
