Ryobi 31cc flywheel
My Feedback: (25)
w8ye: What kind of shaft do you use to place the flywheel in the balancer? Pix? I have one and was trying to figure out how to get the flywheel to rotate in the balancer.
Thanx.
Mike
Thanx.
Mike
My Feedback: (13)
OR
I do the same thing, what I do is take the stationary cone and put that at the small part of the taper, for the other side I either use the cone backward or with an aluminum washer between it and the flywheel
When you get a new flywheel you got to remember not all ryobi flywheels are the same. there is a narrow key and a wide key flywheel. one uses the half moon key and the other type has the key cast into the flywheel. also there are flywheels made by phelon and some mace by walbro. why is that important to note? Because they have different timming in them depending on who made them and you need the coil that matches that timming. so now the question is: What flywheel do you have?????
