OT- Tailwheel for Fokker D-7
I know, it's not an engine question. Guys who convert engines and fabricate are more likely to have an answer, I think.
1/4 scale D-7. First flight was today. I am tickeled, it flew great. 39cc EFCO conversion. The tailwheel won't do. It is the type with a single spring that pokes in to the rudder. It does not have the guts to turn the airplane. Consistent with my modeling philosophy, "Why buy it if you can make it for twice the cost and ten times the labor?" I am thinking of laying up several layers of spring steel leaves and pivoting the wheel with a bell crank. The wheel would stick out behind the rudder and two horns would be attached to the bottom of the rudder. Or, possibly running seperate pull-pull lines back into the fuselage and tieing into the rudder bellcrank directly. Thoughts on my plan of attack? Any better ideas? Where can I salvage or, gulp...buy, appropriate spring steel stock to make the leafspring? Rake tines and recoil starter springs are too narrow. |
RE: OT- Tailwheel for Fokker D-7
You may never be sure of how it works until you try it?
I just had an epophony, hack saw blades with the teeth ground off.
Good find
Keep it simple |
Here are some photos.
http://www.flickr.com/photos/2063862...7625186517220/ I had been posting on a site for scale RC airplane builders. I guess I had used up my freebie posts, maybe 10, and they cut me off and wanted $20. What the heck is that? Hey it is someone's site and they can manage it however they want. I won't be back and they are not getting any money. |
I made a couple out of torsion springs from a VW bug. The front of the old beetles, (Not Super Beetles) use a stack of flat spring plates in torsion. Some are about 3/4" or so wide, but four in the set are half that wide, or about 3/8". I bent one of the narrow ones up and used it as a tail wheel assembly and it works great on my 1/4 scale Giles. Sorry, I am not at home so I can't post a picture.
AV8TOR |
ORIGINAL: Scota4570 I know, it's not an engine question. Guys who convert engines and fabricate are more likely to have an answer, I think. 1/4 scale D-7. First flight was today. I am tickeled, it flew great. 39cc EFCO conversion. The tailwheel won't do. It is the type with a single spring that pokes in to the rudder. It does not have the guts to turn the airplane. Consistent with my modeling philosophy, "Why buy it if you can make it for twice the cost and ten times the labor?" I am thinking of laying up several layers of spring steel leaves and pivoting the wheel with a bell crank. The wheel would stick out behind the rudder and two horns would be attached to the bottom of the rudder. Or, possibly running seperate pull-pull lines back into the fuselage and tieing into the rudder bellcrank directly. Thoughts on my plan of attack? Any better ideas? Where can I salvage or, gulp...buy, appropriate spring steel stock to make the leafspring? Rake tines and recoil starter springs are too narrow. |
I built my giant Eindekker with a skid. Didn't like it. My Fokker DR1 has a steerable tail wheel. I am not that "scale"....
AV8TOR |
I think it depends upon what type of surface you operate off of. Up here in the Pacific Northwest, most of the flying fields are grass, and tail skids are just fine. I do not, however, like using tail skids on asphalt. As for dirt/ gravel runways, well, they are somewhere in the middle.
1 Attachment(s)
Scota4570.
Fokker, so info from the Netherlands. The tailskid wasn’t controlled by the rudder. The centre position was maintained by rubber bands that also were used for suspension, connected with the top of the skid in the fuselage. The skate is made of steel to keep track on grass surfaces, very important part of the skid!!!!! This is my copy of the original tailskid of the DVIII, scale ¼, I think the DVII would not be much different What to do on asphalt or concrete? I don't know, you need something to keep the track!!!! Cees |
The problem is, if you want to taxi with a tail skid, you have to give down elevator, rudder, and a blast of throttle. If you don't coordinate it all perfectly, well then it noses over and at the least you have to go get the airplane, and at the worse you break a prop and/or do cowl/engine damage.
AV8TOR |
1 Attachment(s)
That's right,
People who can do that we call an AV8TOR, you have to learn that. I only doubt a little bit about that down elevator!!!! Cees |
I wish I could fly from grass. I live in central california near monterey. It rains only in the winter here, 15-inches of rainfall is an average year. All mown grass needs irrigation. It is not like other areas where it rains throughout the year. Irrigation is expensive at best and imposible much of the time. The crops around here are irrigated from very deep wells. Getting a permit to tap in to the aquifer is pretty tough and then you have to pay for the electricity to pump it. Basically asphalt is all I have and will ever have around my parts.
How about sprung landing gear? On my first landing I bounced a bit and bent the axles. I bent them back, it was OK. I greased the second landing just fine. I am thinking a bungee system might be a good thing. Anyone have links to how others have done this? |
av8tor 1977 don't you mean up elevator ? If you give it down elevator it will lift its tail and nose over.. The way I taxi is full up elevator to hold my tail down till I Am pointed in the rite direction for take off then I ease off and let my tail come up and when flying speed is achieved I ease back on the stick
No, I did mean down elevator. Like you, I do all my taxi-ing with full up elevator. However, on airplanes with tail skids instead of a steerable tail wheel, you have to give them DOWN elevator and a quick blast of power to raise the tail and allow it to turn when you want to make a turn. If you are not good at it, then yes, you will end up going over on the nose.
AV8TOR |
Why not drive the tailwheel with an extra servo..??
Well certainly, a person could. But the whole idea is in keeping with a "scale" image and having a "drag" like the old airplanes did, instead of a steerable tailwheel. Therein lies the problem in trying to taxi. The old airplanes flew from an "aerodrome" instead of an airstrip. An "aerodrome" was an actual flying field instead of a series of airstrips like we have now. Hence, they could always line up and take off or land literally into the wind. Sometimes (often?), taking off directly into the wind entailed support from the ground crew....
AV8TOR |
ORIGINAL: Scota4570 The tailwheel won't do. It is the type with a single spring that pokes in to the rudder. It does not have the guts to turn the airplane. The wheel would stick out behind the rudder and two horns would be attached to the bottom of the rudder. Thoughts on my plan of attack? |
If his tailwheel spring and/or rudder throw are insufficient to turn the airplane, then the "skid type tail dragger technique" should help him as well. Clearly however, if one wants an airplane to maneuver really nice on the ground, a different tail wheel set up is indicated in this case.
AV8TOR |
| All times are GMT -8. The time now is 09:00 AM. |
