RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   25-31cc Reccomendation for 3 or 4 blade props (https://www.rcuniverse.com/forum/engine-conversions-92/1057218-25-31cc-reccomendation-3-4-blade-props.html)
mikenlapaz 08-15-2003 03:48 AM
What experiece has anyone had using 3 or 4 blade on homies or ryobis? Only guidline I have seen is for 3 blades which says reduce either length or pitch by one inch. What about 4 blades?
Also what is a tractor prop? Just one that pulls vs pushes or is there other differences from say a sport prop that mounts in a 'pulling / standard' method?
w8ye 08-15-2003 04:18 AM
Mike, From my experience, you are correct in your assumtions. On the four blade, you drop 2" or 2 pitches or one of each, whichever will make the plane speed come out correct. You will be limited by what is available.
Tractors pull and pushers push.
Jim
