RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Echo SRM 231 (https://www.rcuniverse.com/forum/engine-conversions-92/10627585-echo-srm-231-a.html)
Scota4570 07-18-2011 04:53 PM
Echo SRM 231
1 Attachment(s)
I got one. I got after it. It has two rings and gobs of compression. It hand starts easily. If I fly it I'll replace the small silly looking carb and make a new intake manifold.
w8ye 07-18-2011 05:35 PM
RE: Echo SRM 231
I have one of these but it is still a weed whacker. It has more power than a Homelite 25. My Echo will remain a weed whacker as long as the weed part holds up.
I have many other model engines this size.
Scota4570 07-18-2011 08:23 PM
RE: Echo SRM 231
It was done as a wacker. It sat in the weather. There was water in the case and jug. The carb was shot. The forged part of the crank was rusty. The bearings even felt bad. After a carefull clean up the only real damage was a bit of pitting on the cylinder bore under one of the transfer ports.
It is quite a runner, over 9K with a 15x6 using that little carb and no muffler. I think with some tinkering it will really sing.
av8tor1977 07-18-2011 09:34 PM
RE: Echo SRM 231
Echos are great engines. I have a lot of them and really like them. High quality, light weight, and powerful.
AV8TOR
Scota4570 07-20-2011 08:19 AM
RE: Echo SRM 231
I had some time to play yesterday. I smoked 40# of pork shoulder for a family get together. There is time to mess around while it is smoking.
Anyway, I gutted the muffler, installed a WT517 (11mm) carb, and made a new intake manifold. 16x7= 8200rpm, 18x10=6900, and 20x8=5600. That is very impressive to me, for a 23cc.
w8ye 07-20-2011 12:49 PM
RE: Echo SRM 231
18 X 8 should be the magic prop
