long coupling hex nut as prop adaptor??
Hello everyone.
Im converting a Mitsubishi 33cc short shaft for using it on a 72 WS ugly stick Im living in México city and its have been hard getting an 8mm prop adaptor (hub) In home depot i found this long coupling nuts which might work, but in México there are only standard chord (not milimetric) Im flying to Louisville kentucky this week, any idea where can i find this long hex nut or any other suggestion of something that might work as prop hub. Regards VA |
RE: long coupling hex nut as prop adaptor??
1 Attachment(s)
This is what I´m talking about
anyone?
They're called coupling nuts.I got one at Fastenal,but many places have them in metric.Check what hardware stores or larger stores are in Kentucky where you're going may have them. https://www.fastenal.com/products;js...goryl1:"600000 Fasteners"|~ ~|categoryl2:"600072 Nuts"|~ ~|categoryl3:"600076 Coupling Nuts"|~ ~|sattr01:^Metric$|~
Have you used these as prop adapters?
Originally Posted by rcairboater
(Post 12068660)
Originally Posted by Tidnab
(Post 12068781)
No, not as a prop hub.I don't think they would be big enough,unless for a very small plane.
| All times are GMT -8. The time now is 09:34 AM. |
