Kavan MKI to gas
I have aKavan MKI to convert This engine is of my Friend Abdul . Is an interesting engine because it has oiling system inside Hope works nice I began conversion tooday Will upload pics Max |
RE: Kavan MKI to gas
I would convert it to ignition and still use a very small amout of oil in the fuel. If you use a glow type carb you can use a mix with alky. If you install a walbro carb, you can use gas...but they recomend a small amout of oil in the fuel even though it has its own oil supply. Capt,n
Oil in the sump, 2% oil in fuel for the valves.
2 or 3 types of carbs, ranging from poor to junk. |
dear Capt John
yes Ill use a walbro this is a beaitfull 50cc twuin 4 strokes engine My best regards max |
ORIGINAL: tkg Oil in the sump, 2% oil in fuel for the valves. 2 or 3 types of carbs, ranging from poor to junk. What kind of oil?? Ill use 5w30 4 strokes car syntetic oil |
1 Attachment(s)
I would & do use the same oil I place in the oil sump. If I use Klotz in the sump...then its Klotz in fuel. If I use Mobile1in the sump...then I add Mobile 1in fuel. I change the oil about every 4th run. This engine will run with only 1 degree difference in temp from onecyl too the other. Made In Germany. Go tohttp://www.mecoa.com/kavan/index.htmfor more data.
Capt,nhttp://www.rcuniverse.com/forum/js/f.../thumbs_up.gif |
1 Attachment(s)
I see thath will need to change engine mount suport in other way because I need some space for the walbro.
I see carb suport was not well tightened, i decided to unassamble some part to fit itcorrectly |
1 Attachment(s)
Finally carb support is ready i will use a Tillotson that for me is too much fine tah walbro.
IS our four strokes design ste modification with special STE valvle |
1 Attachment(s)
Looking good so far. Keep up the good work. Just looked at my Kavan. It seems like the 2 upper mounts could be spaced out a little each way with a fill in adapter...then there would be room for a regular pumper carb. I just may do that to my Kavan. Capt,n
1 Attachment(s)
ORIGINAL: captinjohn Looking good so far. Keep up the good work. Just looked at my Kavan. It seems like the 2 upper mounts could be spaced out a little each way with a fill in adapter...then there would be room for a regular pumper carb. I just may do that to my Kavan. Capt,n I solved with 2 separators and a high resitant allen 8-32 |
Max, looks like a good job in the photos. Is there a rubber spacer in there yet? I may want to get the Dimentions of the parts you made. Thanks Capt,n
| All times are GMT -8. The time now is 04:24 AM. |
