Basic info Rovan 30.5cc
Hello all i ordered my new Rovan 30.5cc motor along with a zenoah prob hub and stud. My question is after looking at pics of the motor where would i put the stud and adapter to attach a propeller to this dang motor? All info and advice appreciated thanks guys!
Originally Posted by jwright36
(Post 12046527)
I do apologize here is a link to the motor. Its a 1/5 baja motor so it has a clutch. Im guessing by taking off the clutch i can install the hub and stud etc on the shaft.
http://m.ebay.com/itm/261861158044?nav=SEARCH |
Another Zenoah type clone engine. The1/5th scale HPI Baja cars/trucks come with Zenoahs stock I believe. I would think you would want the prop hub on the front. This way you can remove the clutch and chop the back side of the crankshaft off and remove the pull starter housing and related framework to save weight. Having the hub on the front also allows the use of normal tractor props. You would need a pusher prop on the back of the engine as the shaft spins clockwise on the back (clutch) side.
ask AV8TOR if he thinks this engine nay make a good conversion. He may have done one !
Originally Posted by 1QwkSport2.5r
(Post 12048250)
(Post 12048609)
Im going to use a Master Airscrew 14x7 3 blade pusher for my setup
(Post 12046527)
The good news is that you can install the crankshaft in any direction as the crank bearings are the same. If you install the standard way you can cut off the excess bit (shroud) and attach to firewall via a mount connected to the crankcase bolts. If you turn the crankshaft the other way you can use the shroud as your mount, in this case you may want to use a Dremel to match the crankcase and cylinder ports. I have fitted a prop adapter but haven't powered any of the two engines yet, being agressively timed and 31mm stroke (+2 mm of original crankshat) I expect very good performance, I think they should turn an 18x8 prop well above 8000rpm. |
Small correction, the stroke is in fact 30mm (28mm standard + 2mm) and bore 36mm, comes with a stuffed crank.
This makes the Rovan the same capacity as the DLE30 but being a piston ported (as opposed to reed valve) it can rev higher with the correct port timing. 18x8 prop should be small enough to get high rpm out of this engine, not sure about the vibration level but this engine can rev very high on cars. |
| All times are GMT -8. The time now is 01:48 AM. |
