Cheap engine block for conversion.
Found these on Ebay and seems like a good engine block to convert to a RC plane engine.
Looks a lot like a Poulan engine, it is a 45.2 cc engine. http://www.ebay.com/itm/390805002207...xe=exe,ext=ext Milton |
It's a Stihl copy.
I have three MS250 Stihl chainsaws and they have excellent power. I have a couple extra engine units and have admired how well they adapt to model use. |
Originally Posted by w8ye
(Post 12123848)
It's a Stihl copy.
While that price certainly grabs ones eye, I'm not sure going from a top brand like Stihl or Echo to a Chinese clone would be a step in the right direction. Then when you deal with coming up with a suitable mounting system, an adapter for the carb and prop, provision for an adjustable ignition sensor, and buy a carb, ignition, and muffler, you're going to have some bucks invested anyway..... in a Chinese engine.
AV8TOR |
Originally Posted by av8tor1977
(Post 12210614)
AV8TOR |
Originally Posted by RZayas
(Post 12210835)
I have considered all of the above but I have also seen chinese engines come and go and the Stihl and Echo seem to be always around and that's precisely the reason I am looking to do a conversion. ...
Sincerely, Richard |
(Post 12210835)
I have considered all of the above but I have also seen chinese engines come and go and the Stihl and Echo seem to be always around and that's precisely the reason I am looking to do a conversion. This past week I went was looking for parts for 2 GMS glow engines (american made - I think) that I have. They worked great for me but good luck finding parts, they are discontinued. The price yeah sometimes it doesn't grab my eye, but because they seem to stick around the longest, parts are plentiful. I just saw that CRRC engines re-did their website, and while looking around I found a 40cc engine that looked exactly like the Stihl/Echo engines, so perhaps they are realizing the trend that I'm seeing. Therefore I still want to do a conversion. By the way hope your back is feeling better av8tor1977. By the way have you checked your inventory of engines to see if you have anything available that I could take off your hands? Thanks
AV8TOR |
To conversion guys in general. It is getting harder to find good conversion candidates. The manufacturers have been forced into making variations of engines for smog purposes that don't work so well and that I personally don't recommend using. They generally use a weird two barrel carb setup, and I am seeing a LOT of them burned up because they run so lean. I wouldn't use one myself.
AV8TOR |
| All times are GMT -8. The time now is 02:33 AM. |
