RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   McCulloch 32 cc disassembly?? (https://www.rcuniverse.com/forum/engine-conversions-92/1173510-mcculloch-32-cc-disassembly.html)
rsieminski 10-01-2003 06:38 AM
How do you get the clutch and pullstart off?
AutoMike 10-01-2003 02:49 PM
RE: McCulloch 32 cc disassembly??
On my Mac I put a flat head screwdriver down the center of the clutch bell and just unscrewed it. Most all of the stuff will come off then leaving just the clutch shoes that aslo will then unscrew off the shaft if I remember right. Mike
Flypaper 2 10-01-2003 02:57 PM
If I remember right the clutch screws off clockwise looking at it from the clutch end.
ZAGNUT 10-07-2003 09:56 AM
whack on it with a hammer...
dave
tkg 10-07-2003 02:38 PM
This is a secret, so you cant tell anybody;)
Remove the spark plug and stuff about 1 ft of a small rope in the spark plug hole. Turn the engine over untill it locks up. Then use a t-25 TORX ( I think thats the size) and losen the bolt. Take off the clutch housing, remove the plastic engine housing AND then wack the clutch with a small hammer and it will unscrew.
