RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   32cc Craftsman/Poulan convert experience (https://www.rcuniverse.com/forum/engine-conversions-92/1439168-32cc-craftsman-poulan-convert-experience.html)
mikenlapaz 01-17-2004 12:45 PM
Picked one up yesterday; I am curious whether it would be worthwhile to convert. Reed valve set-up like Ryobi. It has a small WA219-B Carb (7.14mm), single ring, spring held muffler. The head has fewer fins, but thicker than Ryobi 31. The grey plastic case does not look like it would be as durable/strong as the black material used by Ryobi.
What is the trick to getting those muffler springs off? they are STIFF!
It may just go back to original duty.
flipflop 01-17-2004 01:51 PM
RE: 32cc Craftsman/Poulan convert experience
<What is the trick to getting those muffler springs off? they are STIFF! >
Vice grips and big biceps are what I use:)
mikenlapaz 01-17-2004 04:07 PM
1 Attachment(s)
Note the spring puller next to hammer.
stgrlee-RCU 01-17-2004 05:17 PM
How did you get the clutch off that thing? I am about to give up on mine!!
AutoMike 01-17-2004 07:00 PM
My clutch came off by placing a flat head screwdriver down the center of the clutchbell and removing the screw.
mikenlapaz 01-17-2004 07:50 PM
No clutch on this unit, so it was rather a non-issue.:eek: Rotating the cutting head I came up with resistance of the crank trying to turn over. No free-wheeling of a clutched unit.
Reassembled with some new fuel line and it fired right up.
What is the general tuning routine on a single needle carb, it lost its limiter. Started at 2 out and just kept leaning it out till it had best sound and then back 1/8 turn. This is just for 'see it does run just fine' operation.
stgrlee-RCU 01-17-2004 09:56 PM
Be sure that engine turns the right way, mine turns clockwise.
stgrlee-RCU 01-17-2004 09:59 PM
I got the bell off ok. Its the shoes that I cant get off the shaft.
mikenlapaz 01-17-2004 10:48 PM
They must be threaded on. Can you determine direction of threads CW /CCW? vise it up; Jam the cylinder up with some small line/rope pushed down thru the plug hole; put a strap wrench or worst case a pipe wrench on the clutch shoes and lean on it. Might put some LiquidWrench on and let it set overnite first.
FWIW: This is a list of links relating to 32cc Craftsmen/Poulan
http://[link=http://www.rcuniverse.c...36/tm.htm]32cc[/link]
http://www.rcuniverse.com/forum/Conv...1175485/tm.htm
http://www.rcuniverse.com/forum/Poul..._702112/tm.htm
http://www.rcuniverse.com/forum/Feat..._695807/tm.htm
