RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   In wait for fetherlite 22... (https://www.rcuniverse.com/forum/engine-conversions-92/1657013-wait-fetherlite-22-a.html)
Mitty 03-24-2004 09:03 PM
Good evening friends.
This past monday i bought fetherlite 22cc converted engine that was just cut out and prop adapter snaped on.I havent got it yet but guy said it will need to be trimemd prettier.
Anyways,tonite i went flying my spad and crashed the hell out of it :) Of course nothing happened with alluminum L-channel fuse but the wing broke in two right in da center..I'll fix it easy ,,no problems,BUT i think it happened in a ways because my spad was a little underpowered.I took off and elevated about 50-75 yards and then stalled...nose went up ,sort like in those 'ucando':D and it stalled for a few moments :eek:and then went down.If i had a little more "juice" in my little engine i believe i would of been able to pull it out of stall but heck,,around 11 lbs plane powered by .61 engine is a little underpowered...I think...
I am all excited 'bout engine coming in..Will inspect it and hopefully mount it on my spad..Then.... 'HOLD ON TO YOUR NUTS AND SCREWS!' :D
I was wondering if anyone here using such engine and what the engine mounts looks like..My fuse is a flat piece of wood with two l'channells attached so if any engine mounts that can be mounted on flat surface,please post some pics.
Thanks ahead...
Mitty
w8ye 03-25-2004 12:45 AM
RE: In wait for fetherlite 22...
1 Attachment(s)
This is from the Whacker engines site. I happen to own one and it looks just like this. -- Jim
Mitty 03-25-2004 10:04 PM
Hey y'all. Me again...
I started converting an old weedeater 22cc that been laying in my garage without a sparkplug.It got a ton of dirt on it but it seems to have a good compression.When i took it apart i found that it would make a real easy conversion...I guess thats what you call a long shaft...The flywheel is sitting backwards-fins are on the block side of the flywheel.Then shaft going through the plastic covers of the weedeater and have a clutch on it.I was even thinking about new concept-leaving starter on it just to trim it around but then changed my mind.I know that picture is worth a thousand words .I'll post some maybe tommorow,when i will clean it up.
Good day everyone.
