RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Running a 3-blade prop on a 40cc (https://www.rcuniverse.com/forum/engine-conversions-92/1723591-running-3-blade-prop-40cc.html)
JCaste 04-14-2004 04:23 PM
Hi guys!
I want to buy a 3-blade prop for my 40cc Homie (It will propel a hovercraft, so I think it should give traction rtather than speed), but that's nearly impossible in my area. Do you guys know of a online shop that will have the prop I need (a 3-blade 18x8, maybe)?
Thanks!
av8tor1977 04-14-2004 07:10 PM
RE: Running a 3-blade prop on a 40cc
HI,
For low speed thrust, a large diameter two blade prop generally gives more thrust than a three blade.
Good luck,
AV8TOR
JCaste 04-15-2004 01:16 AM
Hi Av8tor,
I already knew this, for my engine a 22x8 would work fine. However, the prop will be shrouded, and a 3-blade would reduce duct's diameter , which is one of the reasons why I want to use a 3-blade instead of 2. Also, multi-bladed props tend to give more low speed thrust.
JCaste
av8tor1977 04-15-2004 09:00 AM
Ok, then how about mounting two, two blade props at 90 degrees to one another for a four blade setup? It should take nothing more than a longer bolt into your prop hub.
Take care,
AV8TOR
Steve Sanford 04-15-2004 10:09 AM
I did that once with some smaller dia props, cut down the hubs, epoxied them together as well as pinned them, they didn't make near the thrust that a two or three blade made. SS
