RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Ryobi 31cc engine mount (https://www.rcuniverse.com/forum/engine-conversions-92/2015594-ryobi-31cc-engine-mount.html)
barkin_bob 07-23-2004 12:41 AM
Looking for a engine mount for a ryobi 31cc Just getting into gas power planes and putting a ryobi in a giant spad having no luck finding a engine mount tryed Tower and Horizon they offer nothing that will work. Any ideas ????
Lee Belew 07-23-2004 12:47 AM
RE: Ryobi 31cc engine mount
Go to www.jagengines.com
Be patience their web sight is the slowest that I have ever seen.
Lee
donalddresser 07-23-2004 09:24 AM
www.wackerengines.com
barkin_bob 07-23-2004 12:46 PM
Thanks guys thats exactly what I needed.
Sky Viper 07-23-2004 04:52 PM
ORIGINAL: donalddresser
I'll second this nomination!
Peter sells 2 different sizes.
I bought the larger one because I wanted room to "fiddle" while I experiment. I think the shorter one would work out a LOT better inside a cowl.
Peter does a great job and I got my parts in less than 3 business days!
Tom
rcglert 07-24-2004 10:57 AM
1 Attachment(s)
A cheaper alternative is to make the mount from 90 degree angle aluminum channel. I cut two pieces to go on the engine and two mating pieces that go on the firewall. The engine then mounts to the firewall by 4 bolts. Works like a charm and costs less than 10 bucks! The photos are not the best, but they will give you an idea.
Tom
Sky Viper 07-24-2004 10:59 PM
ORIGINAL: tomenglert
Tom
I dinked around a bit with some scraps from work and came up with much the same thing I see here. I tried my rails horizontal and vertical.
I had 2 issues:
1. Too many screws. with screws to hold the angles together and screws to hold the angle to the motor and firewall there are 12 screws minimum. These engines will vibrate. I like to have as few screws as possible. So, I had a friend at work weld them for me.
2. Access to the carb. I would have to cut, drill, machine, file...
Then I found wacker engines!
His mount is really very light, strong, and WELL designed. It's clean and easy to work with. I believe that shipping for just a mount would be $4 or less since he only wanted $4 to ship me an entire kit! The mount is only $15, so for only $19 you could have a wonderful mount that is ready to go!
Tom
rcglert 07-25-2004 09:11 AM
Sounds like a very good deal. I am just a do it myself nut. I like the machining and filing etc. I love punishment I guess!
Good luck with the whacker mount. I have seen one similar to it and it is very nice.
Tom
