RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   different ignition supplier?? (https://www.rcuniverse.com/forum/engine-conversions-92/2038799-different-ignition-supplier.html)
buckeyes1997 07-30-2004 03:21 PM
http://www.mjnfabrication.com/pages/948294/index.htm
would this setup work for RC conversions with their coils. which coils would work well besides the E coil??
thanks
ZAGNUT 07-31-2004 04:20 PM
RE: different ignition supplier??
all the experts will tell you that the modelelctric coils aren't reliable...and look at the weight of that "exciter" coil.....that's one of the drawbacks of a reliable kettering ignition, the other is high current draw.
as for the ignition module, find a distributor from a '80s-'90s japanese car. inside it you'll find a very nice ignition module that works just fine with 6 volts. lighter and cheaper too.
or for a few dollars more than what they want for a module and e coil you can simply get a ch ignition and be done with it
dave
Antique 07-31-2004 06:26 PM
Or an RCIGN module.........
Sky Viper 08-03-2004 04:50 PM
ORIGINAL: buckeyes1997
thanks
I posed this question and others to them via email, below are my questions and Mike's reply:
I am interested in your HED and HED II ignitions.
> Are they Kettering type ignitions or CD?
> I notice that you spec them at 3.6 to 12 V. Do they have built in
> regulators?
> Do you do machine work?
> Have you put together a conversion for Ryobi 31 cc engines so that they
> can be used in model aircraft?
> Thanks,
> Tom
Currently my ignitions are Kettering type only. I do have a CDI in the
final stages that hopefully can be released
in a few months.
The current HED modules do not have regulators, the HED III(coming soon)
will have.
I really don't suggest "full time" operation of these modules as they were
designed to support model engine builders that
usually run their engines for short periods. The CDI (on single cylinder
engines) would be a better choice.
You might try CH Ignitions, they make a really nice CDI for model airplane
use.
Hope this helps............
Mike
Antique 08-03-2004 05:04 PM
Does this mean that TKG and I might just possibly have been correct ?:eek:
Antique 08-03-2004 07:36 PM
RC, TKG,,,You guys got it, right on the money !!!!
tkg 08-03-2004 10:19 PM
:D
