What are the symptoms that indicate a 2-stroke engine has worn rings or cylinder bore? Can you use a pressure guage as on a 4-stroke? Can you feel a difference when pulling a rope starter? Does it show up mostly at start-up, idle, or high speed?
RE: Engine Conversions
I usually keep up with the "FEEL" of my engines by rocking the crank back a forth between my fingers to feel of the bearings and the connecting rod, and then I swing the engine through a few compression strokes and make a personal comparison of the condition of the cylinder-piston. After you get used to this, you can pick up someone's engine and tell all about it's condition without even running it.
Enjoy, Jim |
I can definitely tell a difference with plug out ( little resistance, longer coast-down ) compared to plug installed, so I'll assume I have compression for now. Does low compression affect all running conditions equally ( starting, idle, WOT, transitions ) ?
Thank you. |
Thank you. |
Thank you. |
| All times are GMT -8. The time now is 02:08 AM. |
