RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   A cdi design starting point (https://www.rcuniverse.com/forum/engine-conversions-92/2482157-cdi-design-starting-point.html)
Texas1 12-30-2004 04:47 AM
For those interested in tinkering with a little electronics. The wegsite has the code and board drawings for an atmel microcontroller base cdi. He has several versions all with code and schmatics. The site is in French so you will need to use google's language translator if you can't read French. He design them to fix his ignition on a motorcycle. Its good info for those who want to try a hand at making their own electronic advance timing system for a conversion rc motor.
http://perso.wanadoo.fr/transmic/
platero 01-03-2005 12:12 AM
RE: A cdi design starting point
try www.hpignitions.com.ar they have all the problems solved for a few dollars
ZAGNUT 01-17-2005 03:13 PM
the french site should also have a simpler PIC based ignition that looks good. very easy to look at the code and see what's going on there. most pages are available in english too, just start out at the home page.
happy chip burning
dave
Texas1 01-23-2005 03:01 PM
Another site with good info:
http://www.sportdevices.com/ignition/ignition.htm?
