Ryobi and CH
Started a Ryobi conversion and did not like the clearance between the flywheel and the cowl
Not to mention it would be a little to nose heavy. Well I finally picked up a CH. ignition I originally had a Wacker eng. prop hub on it. I need to keep the same distance from engine to end of prop hub I had with the flywheel installed Now I need to mount the earth magnet. I guess what I need to know is do I buy a timing wheel, or do I cut out the center of the flywheel (don’t even know if that would work) Does anyone make one to match the bevel of the crank and key way(1/16)? The instructions talk about a timing plate and setscrew but is not clear to me. Can you help? Thanks Dennis |
RE: Ryobi and CH
C-H makes it real simple for you if you buy their parts. The hub is keyed in place and the sensor attaches in a manor that the timing is correct.
If you need a longer prop<>engine distance just use spacers? Enjoy, Jim |
RE: Ryobi and CH
Thanks Jim. I have a new C-H setup with everything but the timing hub and thought you had to turn the flywheel. I see now they have a timing kit. I didn't see before guess I'll have to order one. There goes another 2 weeks.
Thanks Again Dennis |
RE: Ryobi and CH
If you have access to a lathe, plus time and patience, you can turn the stock flywheel down to a small prophub. Then you can simply drill a hole in the appropriate place and install a magnet. I have done that for engines that I couldn't find existing prop hubs for. To me, it's a method of last resort.
If a prop hub is commercially available, get it!!! Cutting down the flywheel is just not worth the time and effort, unless you enjoy the work. |
| All times are GMT -8. The time now is 09:40 PM. |
