homey 30cc glow
has anybody tried to run a 30cc homelite on glow. i know it will take a wt-499 carb and an adapter, but does anybody have any performance specs?
RE: homey 30cc glow
1 Attachment(s)
I got a 30cc Homelite in the works....here is a photo. Capt,n
RE: homey 30cc glow
I'm also converting a 33cc Poulan(chainsaw) on glow and it ran on glow with a 18-10 and the stock muffler. Didn't get good numbers as the carb isn't adjusted yet. Using a wt-324 walbro and will need a redesigned test mount as mine wasn't as sound as I had thought and the vibs are high. Still in the works and it will eventually go a a large SPAD.
RE: homey 30cc glow
Maybe the high VIBES was unseating the fuel control needle. Get it (engine) on a good mount and run her again!!! Capt,n PS try a different prop...maybe that will help the vibes
RE: homey 30cc glow
Fixitt here, I have been looking around the forums and found you guys usually I"m on RC air boats I"M an small engine mech. and I tinker with the conversions I have been wondering for awhile if you could run glow or not need some info please thanks alot!!!!
RE: homey 30cc glow
If you don't have an original "GLOW" carb from a Zenoah 23 as mentioned in the first thread, there will be a problem getting enough fuel.
The carb will have to be modified. Enjoy, Jim |
| All times are GMT -8. The time now is 06:07 AM. |
