Homelite 45cc Carb
I have a Homelite 45cc that I want to replace the carb in order to sell a working engine. The carb has never worked right, so I put a carb off a G38 on it and it ran great for quite while until it had to go back on the G38. What is a good replacement carb?
RE: Homelite 45cc Carb
The dimensions are venturi sizes, not the throttle bore size.
The Homelite 45 uses a ZAMA C1Q-H44 =14mm =.551" venturi. Zama's have no number cast in venturi inlet The throttle bore size for theZAMA is 16mm = .630" or a little over 5/8" The G 38 uses a Walbro WT-338 =13.49mm =.531"= #34 cast in inlet Throttle bore is 17.44mm or 11/16" The G 45 uses a Walbro HDA48D =15.08mm =.5937"= #38 cast in inlet Throttle bore is 19mm or 3/4" Enjoy, Jim |
| All times are GMT -8. The time now is 06:18 AM. |
