stihl
went back to the bin that i got the other engines out of and found a 60cc sthil cut off saw
it has broken plastic on it Should make it eaiser to convert what are these engines like anybody done one |
RE: stihl
Hi, I am just finishing up a Super 045 coversion and it was relatively easy. The carb need an adapter since the saw uses a rubber tube to the case where the carb was originally mounted. I am using a C&H ignition. It currently is in NM getting a new set of rings but will be ready by Aug for running.
Good luck |
RE: stihl
My one has a plastic intake manifold so thats a good thing
Damn thing is 3kw so it should be enough grunt |
| All times are GMT -8. The time now is 02:18 AM. |
