RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Carb only has low needle? (https://www.rcuniverse.com/forum/engine-conversions-92/3232861-carb-only-has-low-needle.html)
sides7 08-04-2005 10:30 PM
I have a carb with 0nly a low needle. The location for the high needle is there, but looking into the hole, all I see is a brass looking cap or cover down in the hole. Is there a short needle down there? are the threads there? How do you remove the brass looking thing? What's the fix?
SIDES7
Antique 08-04-2005 11:05 PM
RE: Carb only has low needle?
The wonderful wizards in Washington have decreed that you WILL NOT adjust your carb and make (gasp) :eek: harmful emissions...Get a carb with a high speed needle, that one can't be made to work...:D
davewallace 08-05-2005 12:12 AM
Hi,
I had a carb that had the high speed needle hidden under RTV in a hole. I removed the RTV and there was my needle. Maybe there is a needle under your cap. Try to pop it out with a knife or drill it out carefully. What do you have to lose?
Dave
