RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Looking for conversion help (https://www.rcuniverse.com/forum/engine-conversions-92/3346753-looking-conversion-help.html)
electroman7 09-10-2005 04:11 PM
Hi everyone, I'm looking for someone who can convert my Briggs & Stratton 34CC 4 stroke for R/C use. I want to have electronic ignition installed also. Anyone doing this type of conversion? This motor is destined for a Balsa USA Fokker DVII.
davewallace 09-11-2005 12:40 AM
RE: Looking for conversion help
1 Attachment(s)
Hi,
Here is a picture of one with CDI. I think it is by RCINITIONS or maybe not.
Dave
Antique 09-11-2005 09:42 AM
Yup....The performance was not all that great, less than a stock G23, and heavier....:eek:
davewallace 09-11-2005 03:44 PM
Hi Ralph,
Would it swing a bigger prop, or did you try?
Dave
electroman7 09-11-2005 03:58 PM
ORIGINAL: RCIGN1
Ok, so in your opinion, will it adequately power the Balsa USA DVII? I'm looking for scale like performance.
davewallace 09-11-2005 05:25 PM
Hi,
The Balsa USA 1/4 scale D7 is rated for 25 to 35cc gas engine. With the lifting airfoil it should fly fine. Like a J3 Cub, just slower.
Dave
Balsa USA I/4 scale Fokker DVII
Weight
18 TO 20 LBS Wing Span
88" top wing
69" bottom wing
Wing Area
2225 Sq. In. Engine
25-35cc Gasoline
1.50 4 Stroke
"G-26" OurChoice Fuse Length
68~7/8" Air Foil
Flat Bottom Kit No.
409 Price
$295.95
Antique 09-12-2005 01:02 AM
Do a search in the forum under Briggs and Stratton...There's a picture of one on a big bipe..
The one I had wouldn't swing a bigger prop very well, I got 7500 rpm using a Mejzlik 18-6..
The one on the plane was said to turn a 18-10 very well at first, then 7200 using an 18-8..
I must have "improved" mine worse when I raised the compression and did a little porting..:eek:
A little knowledge is a dangerous thing:D
