RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Please ID this unknown Engine! (https://www.rcuniverse.com/forum/engine-conversions-92/3393974-please-id-unknown-engine.html)
surfrat 09-26-2005 01:05 AM
Hello everyone
I'm a newbie and I came across this engine. All I know is this came out of a snapper string trimmer. I don't know the CC and the engine make. The carb is made by nikki. it has a flywheel in the front with no magnet maybe used as a fan for cooling and a drum in the back with the magnet and the magneto. is this worth converting ? is the shaft long enough for a prop adaptor? Can someone tell me who makes this engine.
TIA
http://fmas1955.org/aimages/snapper/IMG_1739.JPG
http://fmas1955.org/aimages/snapper/IMG_1740.JPG
http://fmas1955.org/aimages/snapper/IMG_1741.JPG
http://fmas1955.org/aimages/snapper/IMG_1742.JPG
http://fmas1955.org/aimages/snapper/IMG_1765.JPG
http://fmas1955.org/aimages/snapper/IMG_1767.JPG
http://fmas1955.org/aimages/snapper/IMG_1769.JPG
http://fmas1955.org/aimages/snapper/IMG_1774.JPG
http://fmas1955.org/aimages/snapper/IMG_1775.JPG
http://fmas1955.org/aimages/snapper/IMG_1777.JPG
http://fmas1955.org/aimages/snapper/IMG_1779.JPG
http://fmas1955.org/aimages/snapper/IMG_1787.JPG
http://fmas1955.org/aimages/snapper/IMG_1788.JPG
http://fmas1955.org/aimages/snapper/IMG_1789.JPG
http://fmas1955.org/aimages/snapper/IMG_1790.JPG
davewallace 09-26-2005 01:25 AM
RE: Please ID this unknown Engine!
Hi Tia,
That is a nice mag setup. For planes you would mount it using standoffs aroumd the mag assy. Put a prop hub on the other end after removing the cooling fan. This way it will turn counter clockwise. It is a Japanese engine, maybe made by Koritz. It should be between 21 and 25cc.
Dave
Antique 09-26-2005 08:11 AM
Those castings are very simular to Kawasaki's.
surfrat 09-26-2005 11:26 AM
Thanks Dave
Do you know who would make a prop adaptor for this?
davewallace 09-26-2005 12:56 PM
Hi Surfrat,
The shaft looks like a 8x1.25mm stud, but you can take the nut to your local hardware store and match it up with a bolt to get the size. Wackerengines.com or Ken Lambert can make one for you. Ken is an RCU user, do a search.
Dave
KenLambert 09-26-2005 10:32 PM
I have a prophub made for one of my stihls that I anodized light blue that is tapped 8x1.25
KenLambert 09-26-2005 10:37 PM
is the muffler an aluminum cast? if it is i have one that is a koritz looks identical to yours
Flypaper 2 09-27-2005 08:17 AM
Most Snappers used Mitsubishi motors and that's the carb they use.
surfrat 09-27-2005 12:22 PM
Yes the Muffler is Heavy aluminum cast and The carb is Nikki. Dont know the size or no Engine Model # or serial on the motor. I Started modifying it today. I'll post some pictures later on. Ken do you have a pic of the engine and the prop adapter? if you do I'll be intrested in the adapter. Thanks to everyone who helped BTW this is my first conversion.
KenLambert 09-27-2005 12:25 PM
I will have to take one
surfrat 09-27-2005 01:57 PM
Thanks Ken
jetski_waxhead 09-28-2005 11:32 PM
Its a mitsubishi engine
td140 by the look of it
1.4 hp
i have one in peices myself at the moment
trying to get a piston for it
And i am not sure if the old engine has the same piston as the new ones
surfrat 09-29-2005 04:17 PM
I did some cutting in it and did a test run. Here is my Ghetto test stand. Dont laugh. I couldn't wait to see it run and make sure it was ok before I spend more time into it. Just bolted it to a A frame Ladder. It ran great. I din't have any load on it other than the Flywheel with the fins for cooling
jetski_waxhead do you have any pics of your engine and any markings on it?
http://www.rcuniverse.com/gallery/ga...s/lg-26834.jpg
http://www.rcuniverse.com/gallery/ga...s/lg-26833.jpg
http://www.rcuniverse.com/gallery/ga...s/lg-26831.jpg
jetski_waxhead 09-29-2005 04:59 PM
i can get some
but they are identical to yours
only mine said mistubishi td140 on it
They are an old engine now
i think they came out on a greens whipper snipper
http://www.mhi.co.jp/sanki/meiki-eng...2st002.htm#003
thisis the latest engines
i am not sure if parts are interchangeable or not
Flypaper 2 09-29-2005 06:47 PM
Another small point, guys, those carbs have a built in fuel pump. No need to put the tank over top.
surfrat 09-29-2005 08:07 PM
How does a built in fuel pump work? Vaccum/suction?
thanks
Flypaper 2 09-29-2005 09:32 PM
It uses the crankcase pulses to operate the fuel pump. pump is under the side cover where the fuel line goes on. The little button on the bottom of the carb is a primer button. With the slide valve open you should be able to pump the button and see fuel squirt into the throat. It's pushing on a metering diaphram that feeds the proper amount of fuel to the engine. A walbro carb would probably work better as this one has a very small throat to restrict RPM. by the way, Its a 24 cc motor. 1.4 cu. in. Hope this helps.
carlosponti 09-30-2005 09:29 AM
also in the picture it looks as if you are using glow fuel line. either use tygon or neoprene. i dont know what will happen but i have heard its bad.
surfrat 09-30-2005 12:17 PM
Oh Good point, possible the silicone glow fuel tubing will breakdown with gas. Thanks for the heads up
surfrat 10-12-2005 08:51 AM
So this is definitly a mitsubishi not a Kioritz? can someone confirm please
thanks
Flypaper 2 10-12-2005 10:30 AM
Kioritz only used Zama and walbro carbs.
jetski_waxhead 10-13-2005 03:37 AM
its a mitsubishi
