RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Kioritz and other engine conversion parts (https://www.rcuniverse.com/forum/engine-conversions-92/3436655-kioritz-other-engine-conversion-parts.html)
Dr Evil 10-08-2005 10:59 PM
Its always something:eek: So I was just going over my newly aquired stash of 5 engines and I have: one 14cc Kioritz, one 23.6cc Kioritz, one unknown brand that looks just like the craftsman weedie that I also got which is of unknow displacement, and an old JC Penny weedie that looks like the Craftsman as well.
My issue is that I hear the Kioritz 23.6cc are awsome little engines, but I don't see any of the manufacturers offing parts for these to be converted. Are they the same in dimention as the Ryobi, Homie, or other popular conversion engine?
I am thinking of using the 14cc on a purpose built plane that should weigh about 6lbs and have a fuselage made of aluminum U tube....hum.
av8tor1977 10-08-2005 11:52 PM
RE: Kioritz and other engine conversion parts
Hi,
Forget the 14cc, it's a dog. Been there done that. No power for the weight. If the 23.6cc is an older model, it's a great engine. Would be a very good engine even if it's not an older model. Can't tell you about parts as I make my own. For mounting I just install four studs with nuts to hold the backplate on. These studs then go through the firewall and get nuts/washers behind. If the engine needs rings, look up Frank Bowman in New Mexico. If you can't make a prop adapter, try Whacker engines. I highly recommend going to electronic ignition such as the CH units. Saves weight, easier starting, and more power as you can optimize the timing.
AV8TOR
Dr Evil 10-08-2005 11:59 PM
Originally I have been interested in doing the gas/methanol glow treatment to the engine. Would this be fool hearted? I figure it would weigh less, and be easier to goof with. I guess that I will be giving Whacker engines a call. I ahve no percision metal working tools (hammer and dremel;))
What thrust could I expect form the 14cc? I am not expecting much as I read all of the archives that I could find on it. I am wondering if I can use it succesfully on a minimalist aircraft built very light. Basically a pole, wing and tail surfaces. If not, maybe I can mount it on a boogie board and make an RC swamp boat out of it?
Thanks for all of your help!
av8tor1977 10-09-2005 12:15 AM
It can be done. If you search the posts for a 16cc Echo/Kioritz you will find the info about the one I did a couple of years ago. I wouldn't do it again as the engine weighs the same as a 21, 22, or 23cc Kioritz and doesn't have much power. It flew my 10 lb. airplane adequately, no great vertical but aerobatic, at sea level but was underpowered when I moved to an elevation of 4400 feet. (And this was all with hop up modifications.) I would vote for the swamp boat idea. I don't know that you could build a 6 lb. airplane with an almost 3 lb. motor that would hold together!
AV8TOR
Dr Evil 10-09-2005 12:18 AM
ORIGINAL: av8tor1977
AV8TOR
I'll just have to make sure to fly it awayfrom me at all times;)
Dr Evil 10-09-2005 12:28 AM
After doing some research here I have decided that the three bigger engines are Poulans. The only thing that sucks is that they have the dreaded spring retained exhaust. IS there anything that I can do with it?
Dr Evil 10-09-2005 12:52 AM
As for the 14cc beastie, how does running two of them on one plane sound? I want to do a twin, and two little guys would probably fit the bill, no? I also want to run it on gas/methanol. I guess that I just can't do anything stock.
buck1856 10-10-2005 10:41 PM
my student is transferring a mculloh 18 cc to glow.fired it up the other day and it was scary.it screamed.hes waiting for a carb of a g23 that works with glow.he drilled the passages out himself in the carb.maybe thats whay it screamed.but he couldnt get a reliable idle and midrange.hes also doing the methanol glow mix to try to save fuel costs.ill watch this thread and post better results.
Dr Evil 10-11-2005 10:18 AM
Thanks, Buck. That is some good news. I can't wait to hear how it turns out.
