RE: cc to flying weight? & what prop?
captinjohn.... Yeah it is a reed valve, compression is good , cylinder walls, and piston really clean. I had to buy new solid state mod but everthing else was good. With the new mod I turned the flywheel by hand and get good strong fire. Just gotta get the hub and muffler and Ill fire it up to see what its got! thanks AL
that engine is looking more like a husky or old homelite , I can't find anything of a poulan with that style setup but makeing a muffler and a hub will be no problem and I will keep looking to find out what it is. Muffler would be 35.00 and prop hub 25.00
Ken, what is the white plastic looking material you use to make your carb spacer blocks? I have one now that is black and was told it is called Duralite.
it is accetel you can get white or black , either one is very expensive I think if not mistaken a 24" peice 1/2" thick 1 1/2 wide was around 30.00 plus shippin
the block are actually to turn the carb to line up the linkage.
is duralite simular to the bakelite ? I will have to check out duralite and see what it is and if it is cheaper.
Ken, I can't find anything from any source regarding the name Durolite. If you stumble on to it please let me know.
Tim |
Ken... your quote is fine.. What do I need to do? Al
paypal is [email protected] or mail is Kenneth Lambert 834 cr 4003 New Boston, TX 75570 either way is fine I will start getting it made.
are you going to use the flywheel and mag or go electronic ? This is a need to know part cause the hubs are different. |
Ill be leaving the flywheel on for now. Seems to have good spark by hand so it should start fairly easy. Ill send payment by mail. Never used the paypal before. Thanks again ken ! Al
| All times are GMT -8. The time now is 08:46 PM. |
