What to do with this?
I have this engine.
http://www.error691.com/meltdown/3/mot1.jpg http://www.error691.com/meltdown/3/mot2.jpg here shown with a 3.5 computer hard drive for scale. It's a two-stroke, 2-hp pump. I don't have precise data on the displacement, but from the size I assume it's 50cc. I've taken it apart, and will remove the water mover when I find a tool that can exert enough torque. The mover is presently seized, as rust has made its job and I haven't been able to take it off with common household tools and generous applications of wd40. http://www.error691.com/meltdown/3/mot3.jpg It had been unused for 10 years or so, and even before that it has seen maybe one hour of running. Anyway, after a good cleaning of the carb (will require some repair as it's leaking lots of fuel out of its lower valve) and general oiling of the crankshaft and piston, I started it up and it ran, so I know it's all right. I intend to remove the whole metal plate where the pump assembly was screwed, and possibly the pull-starter as well (which is removed in the pictures, but I screwed it back on because otherwise I had no means to turn it on). I'm looking for something to do with it. It's power is probably too low, and its weight too high, to be used on a plane, and I don't have the money to buy all the parts for the plane anyway. I was thinking of getting some random junk, a soldering machine, a few servos and build myself a very primitive r/c kart. Do you see any obvious faults in this? Also, do you have any other idea about other uses for it? Thanks :) |
| All times are GMT -8. The time now is 03:14 AM. |
