RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Conversion for carb (https://www.rcuniverse.com/forum/engine-conversions-92/4563691-conversion-carb.html)
jlank 07-30-2006 06:27 PM
Conversion for carb
My Walbro carb has a 24 stamped in the venturie. What size in mm is this? Also where can I get a new arm for the butterfly?
Joel
davewallace 07-30-2006 06:42 PM
RE: Conversion for carb
Joel,
The 24 is 24/64th. It is 9.5 mm. It is a good choice for an 18 to 22cc engine. This is the venturi size (smallest section).
Dave
jlank 07-30-2006 07:00 PM
Dave this a Mac 32cc should I invest in a larger carb. If so what size?
tim220225 07-30-2006 10:39 PM
What is the carb number. IE WT... or WA...? According to my formula you would want to try a carb in the 11 to 12mm range which would give you a venturi of 28 which will be cast into the carb also. For a carb arm you could use a steering nose gear arm. The arm would sit on top of the throttle shaft and be held in place by a socket head screw. There are many other ways too.
TIm
