RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   What engine is this? (https://www.rcuniverse.com/forum/engine-conversions-92/4607154-what-engine.html)
craigblack85 08-10-2006 04:10 PM
1 Attachment(s)
Yes I know another one of these noobs asking "What engine is this?". Well what engine is it? I know it is 22cc. It is from a Mountfield MB22CX strimmer. Is it any good? It looks like it would make a really light engine once all the excess is trimmed away.
thanks in advance
craig black
craigblack85 08-10-2006 04:20 PM
RE: What engine is this?
1 Attachment(s)
another picture!
davewallace 08-10-2006 07:24 PM
Craig,
It looks like maybe a late model Redmax trimmer ot blower engine. 22cc or so. Zenoah engines are based on Redmax puwer equipment. Looks good to me.
Dave
mikenlapaz 08-11-2006 04:10 AM
http://www.echo-usa.com/oot/docs/PB2100T1E_122701.pdf
My guess is 21 cc Kioritz/Echo. Is displacement stamped on unit? What basis for knowing it is 22 cc?
craigblack85 08-11-2006 10:25 AM
1 Attachment(s)
Hi i have the instruction manual that came with the strimmer. The manual says it is 22.?cc, can't remember the last wee bit.
craigblack85 08-11-2006 10:29 AM
Ooops, looking at the pdf the engines are very similar but my head/cylinder mounting bolts are at the oposite sides to the ones in the picture on page 2.
craigblack85 08-12-2006 03:05 AM
Well found out it is a Zenoah G23lh. As used in gopeds and mini motos. So looking for parts for this engine some of the things you can fit are unbelievable. For example: 10 degree flywheel advance key for better acceleration, big bore kit to take the small 22.5cc up tp 29cc!!, a complete new billet head with 13:1 compression ratio, of course there are a lot of tuned pipes and larger carbs. But I think the piece de resistance is NITROUS OXIDE KITS!!!!! Seems like i have got a good wee engine. So what do you think i would be better to use? A standard 25cc poulan with leccy ignition or 29cc 13:1 compression ratio, big carb, tuned pipe and nitrous? You gotta love peoples ingenuity!!
mikenlapaz 08-12-2006 08:43 PM
Glad you identified it. Found one of those a few years ago and posted to get some information.
Check this out:
http://www.rcuniverse.com/forum/m_13...tm.htm#1357451
What plane do you have in mind for either of your mentioned engines?
craigblack85 08-13-2006 12:59 AM
The plane maybe one or both are going in is an Al masters 81inch DO335. Hopefully with the rear engine mid mounted and driving through a prop shaft. thanks for all the help with identifying this engine.
