Echo 2400 Short blocks SB-1034
I went up town to the surplus store in town this afternoon to get a arbor press.
They had 24 new Echo 2400 short blocks for $19.95 each in the box. No flywheel or coil No muffler No carb or carb insulator. http://glenssurplus.com/ |
RE: Echo 2400T Short blocks
W8ye,
You ought to buy a bunch and offer them on RCU or Ebay for a small profit. I'm sure that there are many in this forum who would like to get one or two. Thay make nice EI engines. Dave |
They had one out of the box up on top of the stack. It was just beautiful.
I have a 2400 blower. Might ought to get one for some spare parts? |
I am interested in one of short blocks if you descide to buy them.
George |
I am also intressted if you buy any.
thanks, Jon |
I'll take two or three! Please let me know or PM me.
Thanks, AV8TOR |
I guess I need to run to the store and check out the number again to see if I can find another number?
The short block for most 2400's is part number SB1027 except the blower which is SB1024 The guys that have already ordered them from the store should have them soon. I'm hoping these individuals will elaborate. |
I got one one the way. Its on my credit card anyway. I will post a photo when I get it. I was going to email av8tor as soon as I got one. Up here in Mich the shipping is just over $8 dollars. Best Regards to all. capt,n
Hi. I got two of the short blicks on order this morning They said they would ship them out this morning. Shipping for two brtween ten & fifteen. I can't wait to check them out. then I will have to start looking for parts to get them running. I believe that parts from the 2100 will fit
Thanks George |
for Echo parts also try here http://wisesales.com/index.html Thanks Capt,n
If you start looking at catalogs, you will notice that the Echo 2400 series (23.6cc) has been eleminated in the last few months
1 Attachment(s)
I got my Echo today. The box was so lite.....was there a crank in it??? Yup sure was, and piston rod ect. Came with a set of gaskets too. Now got to find a carb. I have a ignition I bought from RCIGN1. So make a prop hub and go gas or put my golw plug adapter and go glow/gas. Av8tor....please put a photo/photos of one set up for gas/glow. thanks Capt,n P.S. Will post a photo here soon
HEY, THAT WAS QUICK DELIVERY, dOES YOUR BLOCK HAVE A SERIAL # ON IT? EARLY AND LATER TAKE DIFFERENT CARB. & GASKETS
OLDTIMER2; I posted a photo in previous post. Serial no 004400. Capt,n
1 Attachment(s)
It appears to be part # SB1034
Its used on the Hedge Clipper |
Are these the same 23.6cc engines talked about on other past threads that have a lot of HP for their cc's? I remember a couple guys (AV8R ??? & Keith???) saying the older ones were higher HP that the newer Echo's of similar displacement. Something to do with twin rings and large transfer ports.
Thanks, Doug |
1 Attachment(s)
Here's the parts catalog....
http://www.echo-usa.com/oot/docs/HC2...0T1_030502.pdf The 2400's are the 23.6 engines The insulator for the carb is #13001742031 Gaskets only come in a gasket set #88900008460 The differences in the carb area between early and late ones was that it had a different air cleaner. There is only one insulator. In the photo is, I think, what Kieth had to say in a previous post in another thread. |
So W8ye wher do I order one???????
The engine I got was a double ring...other than that.....I do not know. looks good to me. Look at photo. Capt,n ADDED.. click on post 17 for parts file. It also shows 2 piston rings. Aero nut....I will PM the address.
Hello, I ordered two of the short bolcks, I didn't think to ask if they had any flywheels or coils. If you do go by the store again would you ask if they might. If not maybe they could check with thier supplier. In any case I want to think you for the heads up.
Thanks George |
Hey guys, can someone help me out? I'm on vacation out of the country and I can't get to a bank to put money on my debit card. I would like two of these engines! Could someone buy me a couple, and I'll give you twenty bucks profit for the hassle? I can send you the money when I get home Wednesday. Send me a PM to arrange it if someone cares do to this for me.
Thanks, AV8TOR |
Hi, My new short blocks arrived yesterday, They are little jewels. Now I must start rounding up parts to make proper aircraft engines out of them. Any and all hints and suggestions will be appreciated. Also any pointers to parts suppliers. Need mufflers,prop adapters, washers & nuts or bolts. By the way these have L/H threads on both ends of the crank.
Hey Guys.....how do you solve the left hand threads problem....can you buy left hand taps? And where do you buy them?[:-] Capt,n
Hi Capt. I was looking at my Mb 290 this morning and it looks like an exact copy of the echo. My blower is still on tact so I could not compare closely. If you have your Mc out of the blower you might compare. Maybe there is a supply of parts, If you can find any old or broken Mc. I am sure there are tap and dies for L/H threads. I dont know the thread size on the cranks yet.
Later Geroge |
1 Attachment(s)
UPDATE: Did a better check. The Mb290 may be close to the Echo. Not sure they would share internal parts or crank. Carb and exhaust may work. Maybe flywheel. Looks like I am going to have to take the Mb290 blower apart and see. Send me a photo of your Echo if you can.... Please. Capt,n
| All times are GMT -8. The time now is 10:50 AM. |
