RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   ID this Homelite (https://www.rcuniverse.com/forum/engine-conversions-92/5031063-id-homelite.html)
mikenlapaz 11-23-2006 03:03 PM
ID this Homelite
1 Attachment(s)
Unsure of the size and vintage of this homelite. Reportedly RCIGN did the sensor and magnet installation.
mikenlapaz 11-23-2006 03:44 PM
RE: ID this Homelite
1 Attachment(s)
And another Homelite engine that I would appreciate comments on regards suitability and weight. Different than the one in first post.
rangerfredbob 11-23-2006 09:05 PM
acctually if you look close enough, they look like the same engine, but the first one someone chucked the jug up in a lathe and trimmed everything down round... and spent a lot more time trimming the case...
w8ye 11-23-2006 09:46 PM
What did the captions say about the engines in the pictures?
w8ye 11-23-2006 09:55 PM
They are at least 33's.
mikenlapaz 11-23-2006 10:12 PM
If you look at the exhaust outlet they differ in size, shape, and bolt hole patterns. May be same size engine but their are differences and one I suspect is weight. Read searching here that 33 and 40+ used same head at one time which made the 33 heavier than necessary.
w8ye 11-23-2006 10:46 PM
I don't see so much difference in them except the machine work that someone did?
But I have no idea about any exact specs?
mikenlapaz 11-23-2006 10:52 PM
w8ye
Of course you are correct. Having troubles here, too much food to digest. Gee notice how the intake is a different shape on one compared to the exhaust of the other.!! [sm=red_smile.gif]
w8ye 11-23-2006 11:06 PM
I think that is just the way the intake looks on the recent black top saws. The current red top saws have a round intake for a rubber boot.
Speaking of indigestion.... I'm miserable
blackbaron 12-05-2006 05:05 PM
That motor is a either a Homelite 33cc or a 38cc chainsaw engine. It looks like the cylinder was turned down on a mill turn table. The second engine looks like a homelite but the crank shaft is wrong. Homelites have nearly an inch of shaft sticking out before it tapers down to the thread.
